Old Dell Wyse 5010 (Dx0D) thin client for use with DOS (Users)
posted by Zyzzle, 24.02.2026, 12:06
> I connected MS IntelliMouse Optical (tried all ports) and it light up at
> boot but CTMouse cannot find it. Only with option /M it detects COM1 port
> and enable mouse cursor but it doesn't move. It seems that SuperIO IT8721F
> has enabled COM1 and PS/2 but they are not wired out. Maybe could be tapped
> somewhere on PCB...
Damn. Did you try Microsoft mouse DOS driver? Version 9.0, I think, was the latest. Did you try regular non-optical wired mouse with ball? Not sure if those were even made with USB connections.
If mouse is unusable, this limits the DOS functionality. Otherwise, this thin client looks almost perfect.
23247 Postings in 2191 Threads, 405 registered users (1 online)
