VBE3TEST (Users)
posted by RayeR Homepage, CZ, 10.01.2009, 23:26
(edited by RayeR on 11.01.2009, 16:21)
> I tries all four timings but effect is always the same. Almost none.
> The frequencies changes only in range of few hertz (60-65).
> Suprisingly the "highes" rates I got when tried to set 56Hz and 60Hz. When
> program tried to set then higher ones, the real frequency decreased into
> 62Hz-60Hz
Yes, something have to be fixed in sources. Now I don't have time to play with, my task is to fix my vesa bios an disable scaling... If anybody tries to mod it, then please report your result.
EDIT: nVidia BIOS editor (nibitor) can disable on-chip scaler but it still send always 1600x1200 with black frame to DVI. This force 1:1 but I cannot use monitor internal scaler. There must be another way.
22752 Postings in 2119 Threads, 402 registered users (1 online)
